FS: 914-6 GT Double Engine Grill |
PCA7GGR |
Jan 16 2017, 09:53 AM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
Replica of the original double grilled 914-6GT engine lid. It is made with original lid, grills and hardware. The cross brace can be lighten or removed (your choice - the lid is a bit more structurally rigid if the cross brace is only lightened - with the cross brace removed, the lid is lighter but the lid tends to flex and may not fit flush against the trunk when closed). The latch and torsion bars are left intact but can also be removed for race car applications. The lids are painted semi-gloss black (similar to satin black).
The lid is $350 with a core lid (or $400 without a core) plus shipping/packing - cash, cashiers check or Paypal (add 3% for Paypal). Your core lid(s)/grill(s) needs to be in very nice condition (lid has minimal coats of paint, no dents, nor rust and the mesh on grill has no holes nor deformities). If you are providing a stock lid(s)/grill(s), you are responsible for their packing/shipping to me. You can use the box that I send your GT lid in and, upon receipt and if in usable condition, I will refund $50. More pics and info available upon request, Thanks Sergio (sgmeza-at-sbcglobal.net) Attached image(s) |
forrestkhaag |
Jan 16 2017, 03:53 PM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Very nice work here.
Mine has no crossbar and when properly adjusted against the adjustable rubber seats at the back two corners (by lowering the latch to the right pull-down height), there is not an issue with leveling the lid to match the adjacent trunk and side grills, nor movement of the grill. Sergio has a good product offering at a very very decent price - given what is required to fabricate one of these things. (IMG:style_emoticons/default/hissyfit.gif) . How do I know? I built mine out of two lids and after acquiring the two lids in decent shape at the G&R, cutting the two frames in the correct place, welding them together in the correct alignment for the grills to mate properly and securely, sanding, priming, painting, then adjusting to fit, then readjusting, I would suggest buying Sergio's tried and proven product. I would suggest cutting the attaching hinge bracket hole on the lid into a slot for ease of removal and reinsertion on to the bolt - makes a 914world of difference. Also of note. Having run mine w/o a rain tray for around a year now in a Flagstaff snow storm, ice, rain and sunshine, the only thing you might have to add to your car is a couple of rainhats in case of an unexpected downpour. Tupperware works great..... (IMG:style_emoticons/default/lol-2.gif) |
porschetub |
Jan 17 2017, 09:30 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Very nice work here. Mine has no crossbar and when properly adjusted against the adjustable rubber seats at the back two corners (by lowering the latch to the right pull-down height), there is not an issue with leveling the lid to match the adjacent trunk and side grills, nor movement of the grill. Sergio has a good product offering at a very very decent price - given what is required to fabricate one of these things. (IMG:style_emoticons/default/hissyfit.gif) . How do I know? I built mine out of two lids and after acquiring the two lids in decent shape at the G&R, cutting the two frames in the correct place, welding them together in the correct alignment for the grills to mate properly and securely, sanding, priming, painting, then adjusting to fit, then readjusting, I would suggest buying Sergio's tried and proven product. I would suggest cutting the attaching hinge bracket hole on the lid into a slot for ease of removal and reinsertion on to the bolt - makes a 914world of difference. Also of note. Having run mine w/o a rain tray for around a year now in a Flagstaff snow storm, ice, rain and sunshine, the only thing you might have to add to your car is a couple of rainhats in case of an unexpected downpour. Tupperware works great..... (IMG:style_emoticons/default/lol-2.gif) Do you need both torsion springs on our just one,thanks |
PCA7GGR |
Jan 17 2017, 09:36 PM
You can get away with one. It just won't spring up as hard but will stay up.
Lo-Fi Version | Time is now: 8th May 2024 - 08:53 PM |
