WTB: Fog Light Retaining Clips |
PCA7GGR |
Jan 17 2017, 07:51 AM
Member Group: Members Posts: 251 Joined: 3-October 03 From: Dublin, CA Member No.: 1,219 |
Need some early (round) fog light retain clips that secure the lens/reflector ring to the light body - p/n 914 631 961 10. "Previously tested" preferred - ;>) Thank
bdstone914 |
Jan 17 2017, 10:10 AM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Need some early (round) fog light retain clips that secure the lens/reflector ring to the light body - p/n 914 631 961 10. "Previously tested" preferred - ;>) Thank I could use a bunch too. Lets see if Mark can make them. My local fab shop could not do the tight bends. I would like to see them in stainless steel and maybe thicker. I have one clip that is twice ac thick. Not sure what it came from. Bruce |
Mikey914 |
Jan 17 2017, 02:35 PM
The rubber man Group: Members Posts: 12,638 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
I'll look at mine tonight.
Mikey914 |
Jan 20 2017, 12:23 AM
Getting some material in should be able to get these bent up in the next 10 days or so, I will also have to temper these as they are spring steel. So add a few extra days for that. Say 3 weeks?
bdstone914 |
Jan 20 2017, 05:07 AM
Getting some material in should be able to get these bent up in the next 10 days or so, I will also have to temper these as they are spring steel. So add a few extra days for that. Say 3 weeks? Could they be made from stainless or will they be plated? I could use at least 20 |
simonjb |
Feb 23 2017, 06:15 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
Any luck making these?
Mikey914 |
Feb 25 2017, 02:48 AM
These are being blanked and the tooling will be ready in about 5 days. I can have unfinished parts in lets say 10 days, I was thinking about plating them black Zinc, but these are well underway.
Thanks for checking, Mark |
PCA7GGR |
Feb 25 2017, 07:03 AM
Great news - count me in - thanks
bdstone914 |
Feb 25 2017, 07:56 AM
Me too. clear (silver) zinc would be most original.
(IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/piratenanner.gif) |
Mikey914 |
Feb 25 2017, 04:19 PM
One of the few parts not Cad Plated.
Mikey914 |
Feb 25 2017, 04:22 PM
One question. The sample I had has a square punched out of it in the upper bend. I know it's the correct part as I removed it from an assembly. So what's the reason for the variation? Any speculation? I would have thought a clearance issue, and it will still work the same as the not square hole one. I thought the housing had a lip there that it pivoted on, but don't have the parts in front of me right now.
PCA7GGR |
Feb 25 2017, 04:47 PM
Weight savings - used on the GTs.
bdstone914 |
Feb 25 2017, 11:37 PM
One question. The sample I had has a square punched out of it in the upper bend. I know it's the correct part as I removed it from an assembly. So what's the reason for the variation? Any speculation? I would have thought a clearance issue, and it will still work the same as the not square hole one. I thought the housing had a lip there that it pivoted on, but don't have the parts in front of me right now. Was it a TN 4 or TN 1? I just pulled one from a TN 4 and no square hole. I do not think it is needed. I can chech both type housings tomorrow . I think I have seen the square hole on some. |
Biggles |
May 11 2017, 02:59 PM
Member Group: Members Posts: 191 Joined: 5-September 13 From: UK Member No.: 16,353 Region Association: England |
One question. The sample I had has a square punched out of it in the upper bend. I know it's the correct part as I removed it from an assembly. So what's the reason for the variation? Any speculation? I would have thought a clearance issue, and it will still work the same as the not square hole one. I thought the housing had a lip there that it pivoted on, but don't have the parts in front of me right now. Mark in response to your question, one reason might be for the clearance to the tab in the access hole at the bottom of the fog lens rig. My lights are Euro Hella 118 lights and didn't have the retaining clip and to be honest, I don't see how the clip can hold the ring on ? Maybe someone can post a detailed picture of how it looks with the clip screwed in place and if there is a difference to the TN1-2 lights? Chris Attached image(s) |
bdstone914 |
May 11 2017, 04:15 PM
Your clips are missing.
Biggles |
May 12 2017, 11:06 AM
raynekat |
May 12 2017, 12:37 PM
Advanced Member Group: Members Posts: 2,154 Joined: 30-December 14 From: Coeur d'Alene, Idaho Member No.: 18,263 Region Association: Pacific Northwest |
Biggles |
May 12 2017, 03:14 PM
Great thanks. Does it really hold them firmly?
Guess I won't know until I fit one. Waiting for Mark to fabricate some so i can buy. Previous restorer lost mine (IMG:style_emoticons/default/dry.gif) |
Biggles |
Aug 24 2017, 01:10 PM
any update on making these retaining clips Mark ?
raynekat |
Aug 24 2017, 03:46 PM
Yes, these clips are necessary and really do hold the trim rings (and lens) firmly in place.
Great thanks. Does it really hold them firmly? Guess I won't know until I fit one. Waiting for Mark to fabricate some so i can buy. Previous restorer lost mine (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 11:08 AM |
