Vacuum stack elbow, 914rubber------HELP! |
brownaar |
Jan 17 2017, 08:11 AM
Member Group: Members Posts: 263 Joined: 23-September 04 From: Gate City, VA Member No.: 2,813 Region Association: None |
Mark, any chance you'll make these at some point? Just received a new one from somewhere else and the quality............who am I kidding, there is no quality in the hunk I bought.
Thanks, Aaron |
Dave_Darling |
Jan 17 2017, 01:23 PM
You realize you can make something functionally identical with plumbing supplies, right? It'll look vastly different, but a T and a couple of barbed fittings of the appropriate size will indeed work.
--DD |
BillC |
Jan 17 2017, 01:40 PM
Senior Member Group: Members Posts: 536 Joined: 24-April 15 From: Silver Spring, MD Member No.: 18,667 Region Association: MidAtlantic Region |
You realize you can make something functionally identical with plumbing supplies, right? It'll look vastly different, but a T and a couple of barbed fittings of the appropriate size will indeed work. --DD It's not that easy, because of where it fits and the parts it connects. About the only practical way to make a homemade substitute is like what is shown in Frankvw's thread above -- a short length of hose with a metal tube stuck in the side. I don't know about you, but I'd much rather use the correct part than to bodge together a makeshift repair. |
Dave_Darling |
Jan 17 2017, 10:29 PM
It's not that easy, because of where it fits and the parts it connects. About the only practical way to make a homemade substitute is like what is shown in Frankvw's thread above -- a short length of hose with a metal tube stuck in the side. That's absurd! The hose lengths are not at all critical, so you can fit the junction anywhere you like in the engine bay. Longer hoses, some plumbing supplies, and there you go! Note--I am not saying that this is a replacement for the original part, but it is something that should work fine until a quality replacement can be located. --DD |
Lo-Fi Version | Time is now: 19th May 2024 - 01:41 PM |
