1970 porsche 914 wiring questions |
jfab |
Jan 22 2017, 09:03 PM
Newbie Group: Members Posts: 16 Joined: 20-January 17 From: mass Member No.: 20,767 Region Association: North East States |
long story short, the PO cannot wire cars so assume the worst
first is first, im assuming this blue wire is for the horn at the ignition (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.1.jpg) i also found this blue wire attached to the relay board under the kneeboard. guessing this goes to the ignition (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.2.jpg) it is attached to the relay board here, same spade connector as the only non corroded terminal (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.3.jpg) this disconnected wire goes to ground i assume? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.4.jpg) and lastly, what is supposed to go to the pole #6 on this connector? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140580.5.jpg) |
jfab |
Jan 22 2017, 10:53 PM
i just checked my harness and i found about 12 problems with it that would have left me stumped for days.
5 of the pins were in the wrong location (thanks PO) the buzzer wire seems to have been broken off (thanks PO) and now im only missing pin 1 which is not the end of the world i guess, or i can make it work and get my buzzer back making a new harness and getting these electronics finished after my check hits! im so grateful. I have to figure out where 2 more of the wires that were disconnected on my relay board go, but ill tackle that once this work is done! |
Lo-Fi Version | Time is now: 19th May 2024 - 01:57 PM |
