1970 porsche 914 wiring questions |
jfab |
Jan 22 2017, 09:03 PM
Newbie Group: Members Posts: 16 Joined: 20-January 17 From: mass Member No.: 20,767 Region Association: North East States |
long story short, the PO cannot wire cars so assume the worst
first is first, im assuming this blue wire is for the horn at the ignition (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.1.jpg) i also found this blue wire attached to the relay board under the kneeboard. guessing this goes to the ignition (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.2.jpg) it is attached to the relay board here, same spade connector as the only non corroded terminal (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.3.jpg) this disconnected wire goes to ground i assume? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140579.4.jpg) and lastly, what is supposed to go to the pole #6 on this connector? (IMG:http://www.914world.com/bbs2/uploads_offsite/i1067.photobucket.com-20767-1485140580.5.jpg) |
jfab |
Jan 23 2017, 01:56 PM
jeff i have an entire chassis wiring harness and other wiring components from a later car, i believe it has the 14 pin. i also have a few other harnesses. when i get them together ill take pictures and send them your way
Lo-Fi Version | Time is now: 19th May 2024 - 03:44 PM |
