Compensating for a Tee, Deleting the brake compensator |
forrestkhaag |
Jan 23 2017, 10:40 AM
Senior Member Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
Does anyone have the experience and time to briefly describe any needed tricks to delete the brake compensator on an early car / This, so as to make way for a 6 engine mount?
Things like / Is more brake line needed in addition to the "tee" fitting? And is the tee a hardware store item or another "porsche-priced" item that would be metric, brass, and overpriced by 3x?... (IMG:style_emoticons/default/sheeplove.gif) Sounds like a good time to change out all brake fluid as well. I have heard the warnings if one is running 914-4 brake calipers / I am not and have nice beefy 911 calipers which will do the job up front verses in back. Thanks in advance. (IMG:style_emoticons/default/beerchug.gif) |
JmuRiz |
Jan 23 2017, 12:40 PM
914 Guru Group: Members Posts: 5,432 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I had mine removed when I put boxster brakes on the front with stocks on the rear. Should I re-install my stock proportioning valve when I put my car back together again?
mepstein |
Jan 23 2017, 12:56 PM
914-6 GT in waiting Group: Members Posts: 19,301 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
I had mine removed when I put boxster brakes on the front with stocks on the rear. Should I re-install my stock proportioning valve when I put my car back together again? Chances are the rear brakes aren't really going to be doing much against the fronts but I'm all for following a system. When we put boxter fronts in a 911 we usually had SC's or Carrara''s on the back. |
Lo-Fi Version | Time is now: 29th May 2024 - 06:35 PM |
