Compensating for a Tee, Deleting the brake compensator |
forrestkhaag |
Jan 23 2017, 10:40 AM
Does anyone have the experience and time to briefly describe any needed tricks to delete the brake compensator on an early car / This, so as to make way for a 6 engine mount?
Things like / Is more brake line needed in addition to the "tee" fitting? And is the tee a hardware store item or another "porsche-priced" item that would be metric, brass, and overpriced by 3x?... (IMG:style_emoticons/default/sheeplove.gif) Sounds like a good time to change out all brake fluid as well. I have heard the warnings if one is running 914-4 brake calipers / I am not and have nice beefy 911 calipers which will do the job up front verses in back. Thanks in advance. (IMG:style_emoticons/default/beerchug.gif) |
jor |
Jan 24 2017, 04:56 PM
Just happy to be here. Group: Members Posts: 183 Joined: 28-July 14 From: LA Member No.: 17,693 Region Association: Southern California |
The proportioning valve is there to keep the back brakes from locking up when you need them most. When you slam the brakes, the car's weight moves forward and the rear end gets light. The proportioning valve reduces braking power to the rear as the weight transfers forward. Without the valve, the rears can lock and disaster can follow. I was having trouble bleeding the lines with the valve and considered removing it as a quick solution. Sage advice on this forum kept me from removing and, whenever I read something like Brant wrote above, I'm thankful. |
Lo-Fi Version | Time is now: 19th May 2024 - 12:06 PM |
