Compensating for a Tee, Deleting the brake compensator |
forrestkhaag |
Jan 23 2017, 10:40 AM
Does anyone have the experience and time to briefly describe any needed tricks to delete the brake compensator on an early car / This, so as to make way for a 6 engine mount?
Things like / Is more brake line needed in addition to the "tee" fitting? And is the tee a hardware store item or another "porsche-priced" item that would be metric, brass, and overpriced by 3x?... (IMG:style_emoticons/default/sheeplove.gif) Sounds like a good time to change out all brake fluid as well. I have heard the warnings if one is running 914-4 brake calipers / I am not and have nice beefy 911 calipers which will do the job up front verses in back. Thanks in advance. (IMG:style_emoticons/default/beerchug.gif) |
Larmo63 |
Jan 24 2017, 10:05 PM
Advanced Member Group: Members Posts: 4,264 Joined: 3-March 14 From: San Clemente, Ca Member No.: 17,068 Region Association: Southern California |
Not to hijack, but in addition to Forrest's question about the brake compensation valve, what do most here think about keeping the stock 914 sway bar in place on a /6 conversion?
914_teener |
Jan 24 2017, 10:47 PM
914 Guru Group: Members Posts: 5,198 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Not to hijack, but in addition to Forrest's question about the brake compensation valve, what do most here think about keeping the stock 914 sway bar in place on a /6 conversion? My opinion is that depends on tires and spring rates....but for sure I believe more needed on a 6 conversion then on a -4 that is in stock config. Also depends on how you drive the car...as you can tell by some of the racers that responded. I.m a civl engineer and not a mechanical engineer so I know enough to get into trouble and know I.m in trouble. |
Lo-Fi Version | Time is now: 19th May 2024 - 10:56 AM |
