Compensating for a Tee, Deleting the brake compensator |
forrestkhaag |
Jan 23 2017, 10:40 AM
Does anyone have the experience and time to briefly describe any needed tricks to delete the brake compensator on an early car / This, so as to make way for a 6 engine mount?
Things like / Is more brake line needed in addition to the "tee" fitting? And is the tee a hardware store item or another "porsche-priced" item that would be metric, brass, and overpriced by 3x?... (IMG:style_emoticons/default/sheeplove.gif) Sounds like a good time to change out all brake fluid as well. I have heard the warnings if one is running 914-4 brake calipers / I am not and have nice beefy 911 calipers which will do the job up front verses in back. Thanks in advance. (IMG:style_emoticons/default/beerchug.gif) |
Mike Bellis |
Jan 24 2017, 11:25 PM
The PO of my car or PO,PO,PO of my car removed the bias valve and replaced with a T when he switched to 930 brakes. It was a dedicated race car at that time.
I can tell you my brakes work fine and the car stops on a dime. I have no intention of putting it back. |
Lo-Fi Version | Time is now: 19th May 2024 - 03:13 PM |
