Compensating for a Tee, Deleting the brake compensator |
forrestkhaag |
Jan 23 2017, 10:40 AM
Does anyone have the experience and time to briefly describe any needed tricks to delete the brake compensator on an early car / This, so as to make way for a 6 engine mount?
Things like / Is more brake line needed in addition to the "tee" fitting? And is the tee a hardware store item or another "porsche-priced" item that would be metric, brass, and overpriced by 3x?... (IMG:style_emoticons/default/sheeplove.gif) Sounds like a good time to change out all brake fluid as well. I have heard the warnings if one is running 914-4 brake calipers / I am not and have nice beefy 911 calipers which will do the job up front verses in back. Thanks in advance. (IMG:style_emoticons/default/beerchug.gif) |
stugray |
Jan 25 2017, 09:00 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
One thing to keep in mind: The stock prop valve will actuate ONLY when you stomp on the brakes in a (mostly) panic situation. That is because the prop valve acts like a tee until the brake pressure exceeds something like 650-750 PSI.
If you are driving normally you will never know it is there. And the people who race will likely not ever "stomp" on the brake as racers are more skilled and would rarely ever depress the brakes so abruptly. And this statement is incorrect: . . Therefore no matter how hard you press the pedal, no more pressure goes to the rear calipers. . there is an external adjustment to preload the internal valve spring which regulates the valve psi cut-in pressure. . The pressure to the rear brakes WILL continue to increase as you apply more brake pressure only at a reduced rate compared to the fronts. This graph shows that the rear pressure does not go "flat" at the transition point, it still has a slope, just less slope than before the transition: (IMG:http://www.914world.com/bbs2/uploads/post-14886-1390702515_thumb.jpg) |
Lo-Fi Version | Time is now: 19th May 2024 - 11:19 AM |
