1974 1.8 Light Load Stumble |
andrewvolsen |
Jan 24 2017, 10:17 AM
Newbie Group: Members Posts: 44 Joined: 6-December 09 From: Santa Barbara Member No.: 11,099 Region Association: Central California |
My '74 1.8 L-Jet 914 has developed a light load hesitation/stumble. It is the most pronounced when cruising on flat ground with light accelerator application, maybe 10% opening of the butterfly valve. The stumble is not noticeable when accelerating.
The car has: - New vacuum lines - New plugs, wires, cap, rotor, and coil (still running points) - Cleaned throttle body and checked operation of TPS - New accelerator pedal and throttle cable - Rebuilt MAF - Recent valve adjustment Does anyone have any suggestions for how to proceed with diagnosing the cause of my light load stumble (IMG:style_emoticons/default/confused24.gif) |
porschetub |
Jan 24 2017, 12:11 PM
Advanced Member Group: Members Posts: 4,702 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
When was the last time the distributor was cleaned ?,is the advance plate moving freely under vacuum,pull the hose and suck on it ,it shouldn't take much effort.
So many of these distributors are gummed up after all these years. Also check your timing to see you are getting the correct maximum advance ,and your timing is correct @idle. Good luck. |
Lo-Fi Version | Time is now: 24th May 2024 - 06:21 PM |
