Starting issues 2.0 FI |
Fortyeights |
Jan 24 2017, 12:31 PM
Newbie Group: Members Posts: 7 Joined: 28-September 16 From: BRAUNTON Uk Member No.: 20,444 Region Association: None |
Hi,
Just bought a 2.0 FI, which has some starting issues? Turns over fine but takes ages to pick up and fire, then sounds like it only running on two cylinders for about 30 seconds. But following getting it running and slightly warm runs nice. What is the most likely culprit, I'm going to replace all the service parts, fuel pipes and injector seals as a matter of course, is the cold starting valve a likely culprit? I presume it gives extra fuel ? If it is that, is it fixable or is it a replacement job ? Regards Carl |
Fortyeights |
Jan 24 2017, 05:21 PM
Thanks for the help, planning to go through all the basic things first...just thought I'd ask the question. Cars well used but solid and pretty much original apart from an outer respray ......was being used in Cali up until last year.
Cheers Carl |
Lo-Fi Version | Time is now: 11th May 2024 - 02:13 AM |
