Combo Gauge Wiring, PN 914-641-101-50 |
gfg3 |
Jan 30 2017, 10:43 AM
Never Too Old Group: Members Posts: 117 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
I've spent the past several days trying to find a picture of the back of my combo gauge showing the wiring (or a wiring diagram). I have various current flow diagrams and I've found the info for lots of other 914 combo gauges but not for this one (part # 914-641-101-50).
According to the Parts Vault (thanks for the picture - better than I could have done) this gauge was for 74, 75, 76 914/4 2.0 cars which came without a center console. It's mounted on the left side of my dash. Not working properly, but just in case the PO fiddled with it, I'd like to see how it's supposed to be wired before I dive into it. I'm not an electrical expert, so simpler is better. Can anyone help? Thanks. George |
timothy_nd28 |
Oct 12 2017, 11:13 AM
If you put the black/purple wire on a lamp, the engine will cease to run
EdwardBlume |
Oct 12 2017, 11:35 AM
If you put the black/purple wire on a lamp, the engine will cease to run Are you answering the prior post? Where the X goes? I agree that the X misses the mark. If you look in post 1 here, its an amber warning light. Bowlsby's diagram lists it as gauge lighting. #1 |
Jonathan Livesay |
Oct 12 2017, 12:05 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
If you put the black/purple wire on a lamp, the engine will cease to run Are you answering the prior post? Where the X goes? I agree that the X misses the mark. If you look in post 1 here, its an amber warning light. Bowlsby's diagram lists it as gauge lighting. #1 The off white dot is just for looks, no light goes through it, the bulb in that space lights both the gas and temp. gauges. |
Lo-Fi Version | Time is now: 26th April 2024 - 08:22 AM |
