Combo Gauge Wiring, PN 914-641-101-50 |
gfg3 |
Jan 30 2017, 10:43 AM
Never Too Old Group: Members Posts: 117 Joined: 5-January 15 From: Southern Virginia Member No.: 18,295 Region Association: None |
I've spent the past several days trying to find a picture of the back of my combo gauge showing the wiring (or a wiring diagram). I have various current flow diagrams and I've found the info for lots of other 914 combo gauges but not for this one (part # 914-641-101-50).
According to the Parts Vault (thanks for the picture - better than I could have done) this gauge was for 74, 75, 76 914/4 2.0 cars which came without a center console. It's mounted on the left side of my dash. Not working properly, but just in case the PO fiddled with it, I'd like to see how it's supposed to be wired before I dive into it. I'm not an electrical expert, so simpler is better. Can anyone help? Thanks. George |
EdwardBlume |
Oct 12 2017, 01:10 PM
Cool. So the black / blue wire is listed on the original dummy gauge as lighting the gauge cluster (Bowlsby diagram #1), the combo gauge has no place for it, at least listed on the diagram above.
Jonathan Livesay |
Oct 12 2017, 01:43 PM
Senior Member Group: Members Posts: 740 Joined: 13-March 10 From: La Canada CA Member No.: 11,461 Region Association: None |
Cool. So the black / blue wire is listed on the original dummy gauge as lighting the gauge cluster (Bowlsby diagram #1), the combo gauge has no place for it, at least listed on the diagram above. The combo gas/temp gauge does have a place for a gauge light it is the opening for a bulb socket that is behind the off white or beige dot right next to the green oil pressure warning dot. It is actually in the same position as the gauge light on the gauge without temp. gauge. All the lights are the same they just moved the brake warning light from the top position (replaced by the temp gauge) to the left of the generator light. |
Lo-Fi Version | Time is now: 26th April 2024 - 10:39 AM |
