My 73 Suby drivetrain conversion upgrade!, Added a quick video on page 25 |
JRust |
Jan 30 2017, 11:19 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay this has been a long time coming. I am finally going to pull my incredible, reliable, powerfully awesome 158 hp NA 2.5 Subaru Drivetrain. In goes my new 2.5 Subaru Turbo motor out of a 2009 Forester XT. I will be pushing 220 plus depending on if I upgrade my turbo over the stock one. Pretty sure I am sticking with stock to start. That is a pretty easy bolt on upgrade later. I have a 2004 WRX 5speed tranny to mate up to it. Will be doing a firewall engine mount connecting to a Small car motor mount. Tranny ears for the back. Using Outfront header to move the turbo around the front of the motor. Outfront Wiring harness to the Stinger ECU. Still need to figure out the intercooler but staying in the engine bay under a GT grill. More details to follow but plan to pull my old drivetrain this weekend.
Okay so plans have changed & I am going to be putting in this 2005 WRX motor with 55k on it. My 2.5 will go in eventually but my plans are to build it out a little more. Going to get a larger turbo for it & other odds & ends to push 400hp with it. So this 2.0 motor will be pushing 220 easy & looks great Attached image(s) |
Chris H. |
Aug 1 2017, 07:47 AM
Senior Member Group: Members Posts: 4,031 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
Hey Jamie you will get more starter clearance if you switch to a later model one. I just installed part # 23300AA560. Fits perfectly. The solenoid and stuff is positioned to the left instead of directly above the starter housing like the old one was. I can close up the hole I made for the old one now (IMG:style_emoticons/default/headbang.gif) .
JRust |
Aug 1 2017, 10:52 PM
Hey Jamie you will get more starter clearance if you switch to a later model one. I just installed part # 23300AA560. Fits perfectly. The solenoid and stuff is positioned to the left instead of directly above the starter housing like the old one was. I can close up the hole I made for the old one now (IMG:style_emoticons/default/headbang.gif) . Yeah I have 2 used starters I picked up with both of my transmissions. I think one lays over more than the other. I'll test fit them both. If neither of them is I'll use your part # to get the right one. Appreciate you adding the part# (IMG:style_emoticons/default/chowtime.gif) |
Lo-Fi Version | Time is now: 25th May 2024 - 05:54 AM |
