My 73 Suby drivetrain conversion upgrade!, Added a quick video on page 25 |
JRust |
Jan 30 2017, 11:19 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay this has been a long time coming. I am finally going to pull my incredible, reliable, powerfully awesome 158 hp NA 2.5 Subaru Drivetrain. In goes my new 2.5 Subaru Turbo motor out of a 2009 Forester XT. I will be pushing 220 plus depending on if I upgrade my turbo over the stock one. Pretty sure I am sticking with stock to start. That is a pretty easy bolt on upgrade later. I have a 2004 WRX 5speed tranny to mate up to it. Will be doing a firewall engine mount connecting to a Small car motor mount. Tranny ears for the back. Using Outfront header to move the turbo around the front of the motor. Outfront Wiring harness to the Stinger ECU. Still need to figure out the intercooler but staying in the engine bay under a GT grill. More details to follow but plan to pull my old drivetrain this weekend.
Okay so plans have changed & I am going to be putting in this 2005 WRX motor with 55k on it. My 2.5 will go in eventually but my plans are to build it out a little more. Going to get a larger turbo for it & other odds & ends to push 400hp with it. So this 2.0 motor will be pushing 220 easy & looks great Attached image(s) |
914forme |
Jan 31 2017, 02:31 PM
Stock IC is fine even with out the mister. I would do a water to air though. Frozen Boost makes some kist for this, not sure why your limited to 300HP, just get a bigger sized unit.
It has been discussed several times thou, and well every one has done them a bit different. PorSTI uses an air to air intercooler, Scott says he gets temp creep if sitting a long time. It cools right back down once he is rolling. Spending some time in that car, I know it can move. (IMG:style_emoticons/default/happy11.gif) Gray Matter is a water to Air unit, we will see how that one turns out. Good luck with the build and engine sale |
Lo-Fi Version | Time is now: 5th May 2024 - 07:11 AM |
