My 73 Suby drivetrain conversion upgrade!, Added a quick video on page 25 |
JRust |
Jan 30 2017, 11:19 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay this has been a long time coming. I am finally going to pull my incredible, reliable, powerfully awesome 158 hp NA 2.5 Subaru Drivetrain. In goes my new 2.5 Subaru Turbo motor out of a 2009 Forester XT. I will be pushing 220 plus depending on if I upgrade my turbo over the stock one. Pretty sure I am sticking with stock to start. That is a pretty easy bolt on upgrade later. I have a 2004 WRX 5speed tranny to mate up to it. Will be doing a firewall engine mount connecting to a Small car motor mount. Tranny ears for the back. Using Outfront header to move the turbo around the front of the motor. Outfront Wiring harness to the Stinger ECU. Still need to figure out the intercooler but staying in the engine bay under a GT grill. More details to follow but plan to pull my old drivetrain this weekend.
Okay so plans have changed & I am going to be putting in this 2005 WRX motor with 55k on it. My 2.5 will go in eventually but my plans are to build it out a little more. Going to get a larger turbo for it & other odds & ends to push 400hp with it. So this 2.0 motor will be pushing 220 easy & looks great Attached image(s) |
Mike Bellis |
Feb 5 2017, 11:07 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Cut the heads off with a grinder. Once the head is off, they usually spin out by hand if the PO didn't put thread locker on them.
JRust |
Feb 5 2017, 12:57 PM
Chris914n6 |
Feb 5 2017, 02:59 PM
Jackstands are my life. Group: Members Posts: 3,311 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Cut the heads off with a grinder. Once the head is off, they usually spin out by hand if the PO didn't put thread locker on them. How do you cut them off Inside your trailing arm? Undo the big nut and pull the whole thing out (IMG:style_emoticons/default/biggrin.gif) |
JRust |
Feb 5 2017, 05:07 PM
You shut your mouth Chris (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/happy11.gif) . Yeah I can do that. I have always just gotten those bolts out. I plan to now as well. I will do that if I give up on the bolts but I'll get them out.
Chris914n6 |
Feb 6 2017, 01:08 PM
I never mess with those bolts. Too much PITA. R&R with the stub is just so much quicker and easier.
I prefer to waste time with overly complicated things like the Nissan gauge cluster swap. You shut your mouth Chris (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/happy11.gif) . Yeah I can do that. I have always just gotten those bolts out. I plan to now as well. I will do that if I give up on the bolts but I'll get them out. |
Lo-Fi Version | Time is now: 5th May 2024 - 01:00 PM |
