My 73 Suby drivetrain conversion upgrade!, Added a quick video on page 25 |
JRust |
Jan 30 2017, 11:19 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay this has been a long time coming. I am finally going to pull my incredible, reliable, powerfully awesome 158 hp NA 2.5 Subaru Drivetrain. In goes my new 2.5 Subaru Turbo motor out of a 2009 Forester XT. I will be pushing 220 plus depending on if I upgrade my turbo over the stock one. Pretty sure I am sticking with stock to start. That is a pretty easy bolt on upgrade later. I have a 2004 WRX 5speed tranny to mate up to it. Will be doing a firewall engine mount connecting to a Small car motor mount. Tranny ears for the back. Using Outfront header to move the turbo around the front of the motor. Outfront Wiring harness to the Stinger ECU. Still need to figure out the intercooler but staying in the engine bay under a GT grill. More details to follow but plan to pull my old drivetrain this weekend.
Okay so plans have changed & I am going to be putting in this 2005 WRX motor with 55k on it. My 2.5 will go in eventually but my plans are to build it out a little more. Going to get a larger turbo for it & other odds & ends to push 400hp with it. So this 2.0 motor will be pushing 220 easy & looks great Attached image(s) |
matthepcat |
Mar 9 2017, 10:23 PM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
Looks great. You should consider water to air for the inter-cooler (I know you are thinking that).
I'm curious why the A/C wont work with a flipped intake manifold? |
JRust |
Mar 9 2017, 10:50 PM
Looks great. You should consider water to air for the inter-cooler (I know you are thinking that). I'm curious why the A/C wont work with a flipped intake manifold? I am considering water to air yes. On the A/C the problem really isn't the a/c itself but the alternator. With the intake flipped the alternator is in the way of the intake. The options would be to add a 1" spacer below the intake between the throttle bodies. With another inch height it would clear & be fine. The other issue I have is with the turbo & the a/c. Which I do need to remedy as the turbo is right up against the a/c compressor. Which with my setup the oil lines go in right there. Easiest change there is a 1" spacer between the header & the turbo. That would move it up & clear it. Or if I could bend my header towards the firewall a little bit that would also fix the problem. |
Lo-Fi Version | Time is now: 5th May 2024 - 11:12 AM |
