My 73 Suby drivetrain conversion upgrade!, Added a quick video on page 25 |
JRust |
Jan 30 2017, 11:19 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
Okay this has been a long time coming. I am finally going to pull my incredible, reliable, powerfully awesome 158 hp NA 2.5 Subaru Drivetrain. In goes my new 2.5 Subaru Turbo motor out of a 2009 Forester XT. I will be pushing 220 plus depending on if I upgrade my turbo over the stock one. Pretty sure I am sticking with stock to start. That is a pretty easy bolt on upgrade later. I have a 2004 WRX 5speed tranny to mate up to it. Will be doing a firewall engine mount connecting to a Small car motor mount. Tranny ears for the back. Using Outfront header to move the turbo around the front of the motor. Outfront Wiring harness to the Stinger ECU. Still need to figure out the intercooler but staying in the engine bay under a GT grill. More details to follow but plan to pull my old drivetrain this weekend.
Okay so plans have changed & I am going to be putting in this 2005 WRX motor with 55k on it. My 2.5 will go in eventually but my plans are to build it out a little more. Going to get a larger turbo for it & other odds & ends to push 400hp with it. So this 2.0 motor will be pushing 220 easy & looks great Attached image(s) |
JRust |
Feb 3 2018, 06:47 PM
Well after a whole lot of looking & organizing. My garage still looks like crap. I did manage to find 1 of my conversion plates for the MC. I had moved onto my motor. Removed me tranny. Just had it bolted up for test fitting. Still needed to install my Flywheel, clutch & pressure plate. So installed the flywheel & torqued the bolts to 52lbs. Installed the flywheel bearing. Went to install the clutch & pressure plate but I could not find bolts. Looked at the local parts stores with no luck. Ordered some from Subaru dealership. Supposed to be here Wednesday. Going to bolt it to my engine stand. I've got a small car mount on it I am not using. The side with the dipstick tube on it I've got to pull the oil pan to remove. Not a big deal I'll try to tackle it tonight. Taking a break for some dinner. Then need to get pick up some stuff to make Mike Moorman's rotella dip for the big game tomorrow. Good to finally do something on my car. Didn't amount to a whole lot but it is progress (IMG:style_emoticons/default/blink.gif)
Attached thumbnail(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 06:08 AM |
