> My 73 Suby drivetrain conversion upgrade!, New rebuild going in January 2025
JRust
post Jan 30 2017, 11:19 PM
Post #61
Okay this has been a long time coming. I am finally going to pull my incredible, reliable, powerfully awesome 158 hp NA 2.5 Subaru Drivetrain. In goes my new 2.5 Subaru Turbo motor out of a 2009 Forester XT. I will be pushing 220 plus depending on if I upgrade my turbo over the stock one. Pretty sure I am sticking with stock to start. That is a pretty easy bolt on upgrade later. I have a 2004 WRX 5speed tranny to mate up to it. Will be doing a firewall engine mount connecting to a Small car motor mount. Tranny ears for the back. Using Outfront header to move the turbo around the front of the motor. Outfront Wiring harness to the Stinger ECU. Still need to figure out the intercooler but staying in the engine bay under a GT grill. More details to follow but plan to pull my old drivetrain this weekend.
Okay so plans have changed & I am going to be putting in this 2005 WRX motor with 55k on it. My 2.5 will go in eventually but my plans are to build it out a little more. Going to get a larger turbo for it & other odds & ends to push 400hp with it. So this 2.0 motor will be pushing 220 easy & looks great
JRust   My 73 Suby drivetrain conversion upgrade!   Jan 30 2017, 11:19 PM
Krieger   That will be a very nice bump in power!   Jan 30 2017, 11:55 PM
matthepcat   Close to 300 with just a Cobb tune and a bell mout...   Jan 31 2017, 12:03 AM
mgp4591   You've been thinking about this for awhile I k...   Jan 31 2017, 12:17 AM
Andyrew   What are you going to do for the intercooler? Wil...   Jan 31 2017, 12:39 AM
JRust   What are you going to do for the intercooler? Pro...   Jan 31 2017, 01:12 PM
Front yard mechanic   That is a good looking car! Worth the effort :...   Jan 31 2017, 07:00 AM
76-914   I get everything your doing except starting this a...   Jan 31 2017, 09:11 AM
A&P Mech   Jamie, I read your add in the classifieds and it a...   Jan 31 2017, 09:21 AM
Chris H.   So you got it. Nice. Still going back and forth ...   Jan 31 2017, 09:43 AM
rhodyguy   I wish I had known you were going to sell the 2.5 ...   Jan 31 2017, 01:20 PM
Andyrew   If you put an external water mister that activates...   Jan 31 2017, 01:33 PM
914forme   Stock IC is fine even with out the mister. I woul...   Jan 31 2017, 02:31 PM
arne   Starting this weekend, Jamie? I guess we won't...   Jan 31 2017, 02:33 PM
JRust   Starting this weekend, Jamie? I guess we won...   Jan 31 2017, 03:02 PM
arne   Starting this weekend, Jamie? I guess we won...   Jan 31 2017, 03:49 PM
JRust   10:00 Saturday, same location as before. Means yo...   Jan 31 2017, 08:41 PM
Andyrew   You should do some performance runs. 20-60, 40-80 ...   Jan 31 2017, 08:57 PM
JRust   You should do some performance runs. 20-60, 40-80...   Jan 31 2017, 09:05 PM
76-914   You should do some performance runs. 20-60, 40-8...   Feb 1 2017, 09:51 AM
Andyrew   Personally I dont like doing comparison runs with ...   Feb 1 2017, 09:57 AM
JRust   Personally I dont like doing comparison runs with...   Feb 1 2017, 10:24 AM
Andyrew   [quote name='Andyrew' post='2450107' date='Feb 1 ...   Feb 1 2017, 11:23 AM
JRust   Dang that was fast Rich is buying my drivetrain. S...   Feb 1 2017, 11:13 PM
76-914   Dang that was fast Rich is buying my drivetrain. ...   Feb 3 2017, 09:45 AM
JRust   Which route are you going w/ the AC install? :pop...   Feb 3 2017, 12:27 PM
76-914   Which route are you going w/ the AC install? :po...   Feb 3 2017, 03:17 PM
Costa05   Sounds like we both have builds to do. Glad to be ...   Feb 2 2017, 12:02 AM
JRust   Sounds like we both have builds to do. Glad to be...   Feb 2 2017, 12:33 AM
Costa05   I will need to let the PO know his chariot has bee...   Feb 2 2017, 08:38 AM
JRust   I will need to let the PO know his chariot has be...   Feb 2 2017, 11:05 PM
arne   Well Arne I am going to just tear into my car Satu...   Feb 2 2017, 11:29 PM
JRust   Well Arne I am going to just tear into my car Sat...   Feb 2 2017, 11:58 PM
arne   Anytime Arne I am always up to talk 914's PM...   Feb 3 2017, 10:52 AM
whitetwinturbo   :wub: :wub: :wub:   Feb 4 2017, 01:43 PM
JRust   Okay well I've got a few picture. First 2 are ...   Feb 4 2017, 02:06 PM
JRust   Didn't make to much progress yesterday. Ended ...   Feb 5 2017, 10:45 AM
914forme   Didn't make to much progress yesterday. Ended...   Feb 5 2017, 01:03 PM
Mike Bellis   Cut the heads off with a grinder. Once the head is...   Feb 5 2017, 11:07 AM
JRust   Cut the heads off with a grinder. Once the head i...   Feb 5 2017, 12:57 PM
Chris914n6   Cut the heads off with a grinder. Once the head ...   Feb 5 2017, 02:59 PM
JRust   You shut your mouth Chris :poke: :evilgrin: . Ye...   Feb 5 2017, 05:07 PM
Chris914n6   I never mess with those bolts. Too much PITA. R...   Feb 6 2017, 01:08 PM
JRust   My motor plans are changing. I picked up there 200...   Feb 5 2017, 02:29 PM
matthepcat   Decided on the EJ20 huh? What turbo is that?   Feb 6 2017, 01:36 AM
JRust   Decided on the EJ20 huh? What turbo is that? It...   Feb 6 2017, 12:15 PM
JRust   Okay didn't do much this week as work kept me ...   Feb 10 2017, 04:33 PM
dangerranger01   Your car is going to rock! I'd love to hav...   Feb 11 2017, 02:33 PM
JRust   I've got my old drivetrain out! Here are p...   Feb 11 2017, 06:13 PM
strawman   Good job Jamie; keep up the great work. I'm je...   Feb 11 2017, 10:32 PM
JRust   Good job Jamie; keep up the great work. I'm j...   Feb 12 2017, 02:47 PM
strawman   I am using a Type 13 water-air intercooler from Fr...   Feb 12 2017, 06:51 PM
JRust   I am using a Type 13 water-air intercooler from F...   Feb 12 2017, 06:59 PM
strawman   Definitely use a separate cooling system to cool t...   Feb 12 2017, 11:17 PM
Andyrew   http://www.914world.com/bbs2/uploads/post-172-1452...   Feb 13 2017, 12:56 PM
JRust   Hey Geoff what clutch are you running. Stage one s...   Feb 13 2017, 02:30 PM
914forme   lightened is fine your car weighs a lot less than ...   Feb 13 2017, 07:25 PM
strawman   I'm not the guy to ask, since I've got a s...   Feb 13 2017, 07:51 PM
JRust   Sounds like the stage one should be fine then. I...   Feb 13 2017, 08:13 PM
mgp4591   Sounds like the stage one should be fine then. I...   Feb 14 2017, 12:58 AM
JRust   You'll probably be fine with that one, but co...   Feb 14 2017, 12:18 PM
76-914   You'll probably be fine with that one, but c...   Feb 14 2017, 12:21 PM
JRust   Haven't made much progress. Got some bug over ...   Feb 19 2017, 05:54 PM
JRust   Okay a little progress. Took a me a bit but I got ...   Mar 3 2017, 12:24 AM
JRust   Did a little more test fitting. With the tranny ha...   Mar 9 2017, 09:12 PM
Chris914n6   http://www.914world.com/bbs2/uploads/post-129-148...   Mar 9 2017, 11:04 PM
JRust   Flip the mount and assemble it correctly :poke: ...   Mar 10 2017, 12:02 AM
matthepcat   Looks great. You should consider water to air for ...   Mar 9 2017, 10:23 PM
JRust   Looks great. You should consider water to air for...   Mar 9 2017, 10:50 PM
76-914   Looking good Jamie. You'll enjoy the AC. No re...   Mar 10 2017, 10:29 AM
A&P Mech   Jamie, are you smoking the tires off the rims yet?...   Jul 20 2017, 12:54 PM
Andyrew   I think you should triangulate those rear trani mo...   Jul 20 2017, 01:27 PM
76-914   He's probably gnawing at the bits as we speak....   Jul 20 2017, 01:37 PM
JRust   Well not a whole hell of a lot of progress. Bought...   Jul 31 2017, 11:24 PM
914forme   Why is number 7 before number 8. :confused: F nu...   Aug 1 2017, 05:51 AM
Chris H.   Hey Jamie you will get more starter clearance if y...   Aug 1 2017, 07:47 AM
76-914   Hey Jamie you will get more starter clearance if ...   Aug 1 2017, 10:06 AM
JRust   Hey Jamie you will get more starter clearance if ...   Aug 1 2017, 10:52 PM
jimkelly   ditto - thanks for suggestion on later starter and...   Aug 2 2017, 02:32 PM
JRust   Okay I haven't done jack :stromberg: since I...   Feb 1 2018, 07:41 PM
76-914   I'll give you a pat on the back for jumping ba...   Feb 1 2018, 08:47 PM
JRust   Okay now I know why I haven't done squat since...   Feb 3 2018, 12:17 PM
bbrock   Okay now I know why I haven't done squat sinc...   Feb 4 2018, 11:02 AM
A&P Mech   Jamie, I can fix this situation for you. We trade ...   Feb 3 2018, 01:15 PM
six   Jamie, I was beginning to wonder if the project wa...   Feb 3 2018, 06:43 PM
JRust   Well after a whole lot of looking & organizing...   Feb 3 2018, 06:47 PM
76-914   :thumbsup: Way to go Jamie. It will become more or...   Feb 3 2018, 07:06 PM
JRust   Got the motor on the stand today. Flipped it over ...   Feb 6 2018, 12:18 AM
76-914   Got the motor on the stand today. Flipped it over...   Feb 6 2018, 11:53 AM
hockeymutt   Got the motor on the stand today. Flipped it over...   Feb 8 2018, 10:35 AM
Justinp71   Jamie, question- are you still going with the stin...   Feb 7 2018, 12:49 AM
JRust   Jamie, question- are you still going with the sti...   Feb 7 2018, 06:39 PM
914forme   Jamie, why not post a WTB add for the pieces you n...   Feb 7 2018, 12:17 PM
JRust   Jamie, why not post a WTB add for the pieces you ...   Feb 7 2018, 06:45 PM
76-914   More pic's. pls. :beer2:   Feb 8 2018, 09:58 AM
JRust   Well I had some progress today. I also had a setba...   Feb 10 2018, 06:26 PM
Chris H.   Hmmm...that's weird. Can you post some pics o...   Feb 10 2018, 09:36 PM
JRust   Hmmm...that's weird. Can you post some pics ...   Feb 10 2018, 10:04 PM
Chris H.   Yes the engine sits farther forward with the cradl...   Feb 11 2018, 09:23 AM
JRust   I heard from Brent & he made those tranny hang...   Feb 11 2018, 07:55 PM
6 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 13th September 2026 - 10:32 PM
