Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
jim_hoyland |
Feb 5 2017, 06:09 PM
Get that VIN ? Group: Members Posts: 9,284 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Got this from one of Chris Foley's posts
in A:F ratio, you want to see: 13.5-12.9 on the gauge while accelerating or climbing, 12.8-12.5 at WOT, and 16-17 while cruising, going downhill or decelerating. Right now I am in those ranges with FI. A little richer on WOT as I can get to 11.5 at times. But seems to run well in these ranges. |
Lo-Fi Version | Time is now: 12th May 2024 - 01:16 PM |
