Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
jim_hoyland |
Feb 5 2017, 07:37 PM
Get that VIN ? Group: Members Posts: 9,282 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
My experience ( before and after the top end rebuild and new TB) is 12-13 idling in the am; constant cruising speed 14-15.5; up hills it richens a bit.
I used the innovative as the AFR for 3 years; just removed it though. |
Lo-Fi Version | Time is now: 12th May 2024 - 06:38 AM |
