Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
ottox914 |
Feb 5 2017, 10:34 PM
The glory that once was. Group: Members Posts: 1,302 Joined: 15-December 03 From: Mahtomedi, MN Member No.: 1,438 Region Association: Upper MidWest |
Getting idle and AFR can be a challenge. As the engine warms up, things expand, adjustments can change, seals seal better. In tuning the ITB's on my car, I find that it liked around 12:5 or less at idle. If you open the throttles slowly, the afr would take a dive just as the throttle plates opened, and came back to a more expected level just after that. Listen to your engine, give it what it wants. The guidelines are just that- expected guidelines. Let the motor tell you what it wants to run best, and do that.
Lo-Fi Version | Time is now: 13th May 2024 - 09:07 AM |
