Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
PlaysWithCars |
Feb 6 2017, 12:10 AM
Senior Member Group: Members Posts: 524 Joined: 9-November 03 From: Southeast of Seattle Member No.: 1,323 Region Association: Pacific Northwest |
Peak power is made around 13.5:1, idle is usually smooth at that level as well. You can run leaner at cruise for fuel economy especially if you have load sensing for timing advance (vacuum advance or programmable system). You can get as lean as 15s if you can advance timing enough, but be sure your system will retard and richen as soon as you put a load on it or detonation and eventual damage will occur.
Lo-Fi Version | Time is now: 12th May 2024 - 05:37 PM |
