Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
timothy_nd28 |
Feb 6 2017, 07:05 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
I think it would be a cool gauge to have. Would it be better to have it as part of the car or a tool in your toolbox?
Mark Henry |
Feb 6 2017, 11:06 PM
I think it would be a cool gauge to have. Would it be better to have it as part of the car or a tool in your toolbox? Yes I do this all the time BUT for some odd reason the lambda doesn't like to be removed and reinstalled many times. After it has been in several cars they tend to fail. They also seize in place, but using an anti seize paste they often don't ground properly. Believe me at $80-$100 a pop I'm damn careful removing and installing them, but they still fail. Leave it alone and they will last 100K+ miles. If it's dedicated to the one car leave it installed on the car. Aftermarket FI you have to have a O2 sensor for the computer. |
Lo-Fi Version | Time is now: 12th May 2024 - 10:50 PM |
