Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
Porschef |
Feb 7 2017, 05:21 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
It's a great tool to have, especially if you're going to start messing with the AFM. I picked up an Innovate, from eBay, almost 4 years ago. Works fine. My car runs well, but cold start up requires a foot on the throttle for 30-60 seconds, depending on temp.
Hope to get it on a lift within a month for a good valve adjustment and some push rod tube seal replacement... (IMG:style_emoticons/default/dry.gif) |
Lo-Fi Version | Time is now: 12th May 2024 - 08:01 PM |
