Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
ConeDodger |
Feb 7 2017, 08:51 PM
Apex killer! Group: Members Posts: 23,584 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
The good thing about a CHT gauge is you know your CHT. The bad thing? You know your CHT. (IMG:style_emoticons/default/blink.gif)
These engines are highly dependent on fan speed. I found 5th gear with good stock EFI to be almost unusable! |
Mark Henry |
Feb 8 2017, 07:33 AM
The good thing about a CHT gauge is you know your CHT. The bad thing? You know your CHT. (IMG:style_emoticons/default/blink.gif) These engines are highly dependent on fan speed. I found 5th gear with good stock EFI to be almost unusable! 3000 rpm rule, for proper cooling never drive below 3000rpm. Don't lug those engines boys! |
Lo-Fi Version | Time is now: 13th May 2024 - 01:29 AM |
