Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
jcd914 |
Feb 10 2017, 12:55 AM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
If your air flow meter has been mucked with already it can be very hard to get set correctly.
I had a 78 VW Bus 2.0L L-jet that the AFM had been messed with. There is an adjustment for the wiper arm relative to air flow flapper that affects the fuel mixture as well as the spring tension adjustment. I had to play around quite awhile to get the 2 adjustments working together and get proper fuel mixture at different loads. It has been too many years to remember my methodology. I believe I ended up loosening the spring so I would get more flap movement for the same air flow but then moved the wiper to lean it out some to avoid excessively rich mixtures. Of course what I had to do to mine would have been relative to what the PO had done to it before I got it. I eventually ended up with a good running bus that ran lean enough to pass smog and get good mileage without cooking the motor. I was using a 12 volt portable 4 gas exhaust analyzer hooked up everywhere I went for some time. Good Luck Jim |
Lo-Fi Version | Time is now: 13th May 2024 - 09:20 AM |
