Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
Porschef |
Feb 10 2017, 12:06 PM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
IIRC, I'm at 13.2 or so at cruise. The engine seems to like that. Idle im just over 14.
Have you seen the Itinerant Air page? Kinda gives the overall impression that the engine will dictate what it wants, then you have to fine tune from there. Of course, there shall be no vacuum leaks... |
malcolm2 |
Feb 10 2017, 03:26 PM
Of course, there shall be no vacuum leaks... That is where the AWESOME smoke machine comes in. I still see some wisps of smoke, but very little. I think I will smoke it a bit in the morning and see if I can knock the remainder out. The dip stick was one. I added an o-ring but have not re-smoked since that addition. The hose to the fuel reg was one, but I had some slack in the hose, so I cut it off a bit. I seemed to see some coming from under the distributor. Is that possible? These are very lite amounts of smoke, very tuff to tell for sure. |
Lo-Fi Version | Time is now: 12th May 2024 - 08:23 AM |
