Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
timothy_nd28 |
Feb 10 2017, 04:10 PM
If you have smoke coming out from the dizzy, you will need to replace the shafts' O ring.
malcolm2 |
Feb 10 2017, 04:58 PM
If you have smoke coming out from the dizzy, you will need to replace the shafts' O ring. well damn. That is what I thought might be the issue. If the smoke is coming from there. That damn WASHER is gonna cause problems, and then I have to set the timing again. Who sells them? Guess I better check the parts catalog for a part #. Tim, You are always telling me bad news. It is usually right. (IMG:style_emoticons/default/bootyshake.gif) EDIT>>> I found them. AA has them for $1. it is always a nickel holding up a dollar on this car. And AA just closed 9 minutes ago. |
Lo-Fi Version | Time is now: 12th May 2024 - 07:34 AM |
