Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
timothy_nd28 |
Feb 10 2017, 05:23 PM
AA is now closed, so now your thinking RTV? (IMG:style_emoticons/default/biggrin.gif)
You should also check for vacuum leaks at the valve covers while your waiting. |
malcolm2 |
Feb 11 2017, 08:37 AM
AA is now closed, so now your thinking RTV? (IMG:style_emoticons/default/biggrin.gif) You should also check for vacuum leaks at the valve covers while your waiting. RTV on the ditzy hole? Great idea. (IMG:style_emoticons/default/blink.gif) Under the car? Very nice. Gotta remember to look. Charcoal is lit now. |
Lo-Fi Version | Time is now: 13th May 2024 - 03:46 AM |
