Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
Mark Henry |
Feb 10 2017, 06:24 PM
Just a FYI, PLX has their O2 WB meters on sale $160 for the gauge type or $190 for the bluetooth.
Bluetooth has no gauge, you use your phone, tab, ipad, etc., but you can also install a gauge for extra coin. http://www.plxdevices.com/PLX-Wideband-O2-...auges-s/125.htm |
malcolm2 |
Feb 11 2017, 08:33 AM
Just a FYI, PLX has their O2 WB meters on sale $160 for the gauge type or $190 for the bluetooth. Bluetooth has no gauge, you use your phone, tab, ipad, etc., but you can also install a gauge for extra coin. http://www.plxdevices.com/PLX-Wideband-O2-...auges-s/125.htm So with bluetooth you can buy a sensor for each car then use the same "display" phone or tablet? Cool idea. I tried a bluetooth OBD2 set up. But it only works with Samsung stuff not apple. |
Mark Henry |
Feb 11 2017, 10:16 AM
Just a FYI, PLX has their O2 WB meters on sale $160 for the gauge type or $190 for the bluetooth. Bluetooth has no gauge, you use your phone, tab, ipad, etc., but you can also install a gauge for extra coin. http://www.plxdevices.com/PLX-Wideband-O2-...auges-s/125.htm So with bluetooth you can buy a sensor for each car tha use the same "display" phone or tablet? Cool idea. I tried a bluetooth OBD2 set up. But it only works with Samsung stuff not apple. It says "Smartphone connection - Compatible with Apple and Android" On the con side so far it only works with their WB and vac/boost gauges. |
Lo-Fi Version | Time is now: 13th May 2024 - 08:54 AM |
