Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
timothy_nd28 |
Feb 14 2017, 01:47 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Those numbers are better than the 18+ numbers you were getting earlier with a barely running engine. I think you are in the ballpark, but fine tuning is needed.
I also think it's time to re-introduce the AAV to your setup to assist with cold weather starting. |
malcolm2 |
Feb 14 2017, 02:37 PM
Those numbers are better than the 18+ numbers you were getting earlier with a barely running engine. I think you are in the ballpark, but fine tuning is needed. I also think it's time to re-introduce the AAV to your setup to assist with cold weather starting. Yeah, we thought the meter was messed up... nope, it was just super lean. I have AAV re-install in the plan. I will probably get to it before the weekend. Time to change the oil too. Maybe my Disty O-Ring will show-up and I can add that to the list. It has been running rich and ruff for about 2 minutes on these cold morning starts. |
Lo-Fi Version | Time is now: 13th May 2024 - 01:19 PM |
