Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
pete000 |
Feb 14 2017, 04:29 PM
Senior Member Group: Members Posts: 1,885 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Great read, I am in the exact situation with my 1.8 L-Jet. Even built the smoke machine to verify for no leaks. Worked great. Haven't messed with the flapper box yet, but I have a strong feeling mine is lean. My borrowed Wide band gauge is not too easy to get set up for actual driving. I think welding in a bung is next inline for me. The Innovative tail pipe quick O2 mount seems problematic.
I might just have to invest in the Blue tooth solution you shared the link to, pretty cool ! |
Lo-Fi Version | Time is now: 12th May 2024 - 11:28 PM |
