Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
timothy_nd28 |
Mar 7 2017, 11:22 AM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Be careful. The air flow meter has a wound up clock spring that will take off on you when you loosen the retaining screw and if you don't keep constant pressure on it. There is a air flow meter bible that you should read and re-read 3-4 times before making any adjustments.
malcolm2 |
Mar 7 2017, 02:16 PM
Be careful. The air flow meter has a wound up clock spring that will take off on you when you loosen the retaining screw and if you don't keep constant pressure on it. There is a air flow meter bible that you should read and re-read 3-4 times before making any adjustments. http://www.itinerant-air-cooled.com/viewto...f=50&t=7761 |
Lo-Fi Version | Time is now: 13th May 2024 - 11:07 AM |
