Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
Mark Henry |
Mar 10 2017, 03:04 PM
Was your wire feed sticking?
You likely need a new whip liner, but you could also try to make you whip as straight as possible. |
malcolm2 |
Mar 10 2017, 03:10 PM
Was your wire feed sticking? You likely need a new whip liner, but you could also try to make you whip as straight as possible. I had the heat set high (3) to begin with and it ran nicely. But if I did not keep moving consistently... I burned some holes in the thin pipe. Turned down a notch and I got no holes, but did get some spatter and wire sticking on the work piece. Did not think of keeping the whip straight. I will pay attention to that next time. |
Lo-Fi Version | Time is now: 12th May 2024 - 01:21 PM |
