Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
72hardtop |
Apr 24 2017, 05:38 AM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
This is a great graph for air cooled engines:
https://www.thesamba.com/vw/gallery/pix/1463782.jpg 14.7-15 or so is the 'No go zone' danger. Shoot for ~12.5 - 13.0 WOT/Accelerating and while at cruise (part throttle cond) 16-17 AFR Use an LM-2 wide band 16-17 AFR at cruise (part throttle cond) is cooler running (EGT's/CHT's) than 13:0-13:5 same scenario. |
Lo-Fi Version | Time is now: 12th May 2024 - 07:04 PM |
