Air/Fuel ratio, is there a quick answer? |
malcolm2 |
Feb 5 2017, 05:50 PM
OK, I have been tinkering with the new-to-me AFM on my 1911cc engine all weekend. I have adjusted the spring about 20 teeth CCW to get to this point.
I have been using an A/F sensor and gauge. can someone tell me, or direct me to a chart/table of what A/F I should be shooting for on my daily driver. The last adjustment of the CO screw has left me here: I have always had a strange idle situation, so lets ignore that for now. any normal adjustments to reduce the idle at normal operating temp eventually stall the car. A problem for another post. (IMG:style_emoticons/default/blink.gif) the idle is high.... at 1200 the A/F is a smooth 12.2. I found a long hill and drove up it at about 3800 rpm and the A/F was 12.5. thoughts? |
timothy_nd28 |
Feb 7 2017, 08:47 PM
350 degrees is not normal, atleast I hope not. Remove the thermostat cable and repeat the test.
VaccaRabite |
Apr 27 2017, 09:13 AM
En Garde! Group: Admin Posts: 13,442 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
350 degrees is not normal, atleast I hope not. Remove the thermostat cable and repeat the test. 350 going up hill at 70 sounds pretty good to me, especially if the CHT is reading cyl 3 and you are in 5th gear. My car always used to be approaching 400 on long highway hills in 5th. It would be pulling like a champ, but getting hot. I learned to downshift to 4th at the base and keep that air moving. That said I never had valves stretching on me. Now that I'm in EFI and have a wideband I'm looking forward to see if my engine stays on the hot side or if its now going to run a bit cooler. But I'd love to see 350 at 70MPH running up some of the long ass hills here in PA. Zach |
Lo-Fi Version | Time is now: 12th May 2024 - 09:16 AM |
