Local guy wanted too much to powder coat my engine tins, So I built an oven instead |
stugray |
Feb 5 2017, 07:05 PM
I wanted to powder coat the engine tins myself but some of the pieces are pretty large.
And I wanted to be able to do my steelies as well. So I had a 48"X30"X30" gang box in my backyard taking up space. I bought a old working electric oven from a local scrapyard for $10 and it worked. Pulled the guts out of it for the demonstration. First I built a "core skeleton" to hold the inner box and the coils: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1486343146.1.jpg) It's useable space will be 18" X 18" X 36". Then I lined it with aluminum foil and 2X layers of R13 fiberglass with the paper removed. (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1486343146.2.jpg) Then I finished out the box and installed the coils: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1486343146.3.jpg) Finally I made a hollow metal box for a lid and packed it with more fiberglass and finished: (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1486343147.4.jpg) It works for a couple of first runs, but the heating is way too extreme when the coils turn full on. I expected this behavior because the oven has almost zero thermal mass inside the oven cavity. So I will install a thermal shield over the coils out of steel plate (like 3/8" or so). That should slow the response time of the oven and give a much more control-able temp. I also ordered some 240V Solid State relays. I'll stick a raspberry pi to it with a temp sensor and allow it to control the coils with wifi access and control. I also have a temp datalogging capability I will incorporate. I will post some pics of doing my engine tins. They are stripped ready for me to decide what color I want to do them in. I have stock-like Matte Black, Semi-Gloss Black. I also have clearcoat, and "Black Chrome" which is really just a smoky, highgloss clearcoat. So I am considering putting that or clear over the stripped clean metal engine tins. I like the look of the bare metal scrubbed clean. Even with the imperfections and few bits of rusty patches, it looks kind of "steam-punk" and I might go with it. I'll post some pics of the tins soon. |
ConeDodger |
Feb 5 2017, 08:55 PM
Apex killer! Group: Members Posts: 23,602 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
Nice job! McMark also built his own oven. He left it behind when he went to Michigan. I wonder if he'll build another? (IMG:style_emoticons/default/dry.gif)
stugray |
Feb 5 2017, 11:18 PM
Here are the engine tins:
(IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1486358291.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1486358291.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i366.photobucket.com-10819-1486358292.3.jpg) The rear one is the only one that has had a final prep. So what does everyone think of just giving these main tins basically a clear coat to keep that raw look? And for the careful observers, yes my tins have been modified. 1 - I have an access hole to allow me to get to spark plug#3 for a CHT probe 2 - I have cutouts on each side of the engine to clear my suspension pickup point supports |
McMark |
Feb 6 2017, 07:22 AM
Love the suspension cutouts. (IMG:style_emoticons/default/wub.gif)
Nice job! McMark also built his own oven. He left it behind when he went to Michigan. I wonder if he'll build another? (IMG:style_emoticons/default/dry.gif) No it's here. (IMG:style_emoticons/default/wink.gif) Wood framing, mineralwool insulation. And I've had it beyond 700-degress (by accident) without issue, though I do not recommend it. I used a couple controller modules and 220v relays off eBay to add temp control and power timer. But I'm thinking about selling it since blasting and applying powder takes quite a long time and for me I'm not sure the cost-benefit works out the right way. |
brant |
Feb 6 2017, 09:18 AM
914 Wizard Group: Members Posts: 11,628 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
Very nice!
Did you chemically strip the pieces? Good job. Nice build |
stugray |
Feb 6 2017, 09:29 AM
Very nice! Did you chemically strip the pieces? Good job. Nice build I stripped the pieces with Zep purple degreaser at high concentration. Soaking each piece for a few hours with a heater in the tank stripped almost all of the original paint. Final prep was a wire wheel on a 4" grinder or green scrub pads. How do you think the tins will look with the bare metal and clear coat? I thought it would brighten up the engine bay a little more than the boring black. |
JeffBowlsby |
Feb 6 2017, 09:36 AM
914 Wiring Harnesses Group: Members Posts: 8,522 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Did a search...you've been working on this project awhile!
http://www.914world.com/bbs2/index.php?sho...;hl=chrome+tins I saw some chrome tins once, did not look good in my opinion. See the thread for some great painted solutions. |
stugray |
Feb 6 2017, 10:00 AM
Did a search...you've been working on this project awhile! http://www.914world.com/bbs2/index.php?sho...;hl=chrome+tins I saw some chrome tins once, did not look good in my opinion. See the thread for some great painted solutions. I had forgotten about that thread. Back then I used rattle can paint and found that it just wiped right off if it got gasoline on the tins. Now that I had the engine out again I decided to do it right this time. |
matthepcat |
Feb 6 2017, 10:05 AM
Meat Popsicle Group: Members Posts: 1,462 Joined: 13-December 09 From: Saratoga CA Member No.: 11,125 Region Association: Northern California |
What about color matched to the paint job?
stugray |
Feb 6 2017, 10:25 AM
McMark |
Feb 6 2017, 01:01 PM
Too matchy-match for me. (IMG:style_emoticons/default/tongue.gif) Plus engine's are dirty places. If you coat it green, you better love spending time cleaning, or not be OCD. (IMG:style_emoticons/default/laugh.gif)
JeffBowlsby |
Feb 6 2017, 04:16 PM
The quality and durability of a paint coating application is not only the quality of material but also priming and surface preparation. Prolly don't need to tell you that.
An $8 rattle can paint job is in no way comparable to a high quality application using quality materials and workmanship. I have seen powder coatings fail too. Must check all the boxes to get it right. |
brant |
Feb 6 2017, 07:05 PM
Very nice! Did you chemically strip the pieces? Good job. Nice build I stripped the pieces with Zep purple degreaser at high concentration. Soaking each piece for a few hours with a heater in the tank stripped almost all of the original paint. Final prep was a wire wheel on a 4" grinder or green scrub pads. How do you think the tins will look with the bare metal and clear coat? I thought it would brighten up the engine bay a little more than the boring black. It might look very cool I would hold the on the motor or engine bay and view first. But I like the idea I have a bare motor in the middle of my garage if you need as a point of reference |
Lo-Fi Version | Time is now: 29th May 2024 - 12:00 AM |
