Troubleshooting my electrical issues., My first problem was blinking red light on the dash for brakes |
vin man |
Feb 11 2017, 06:08 PM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
Edit: Renamed the thread because what started out as one electrical problem has led to others and I'm hoping to capture all the information in this one thread.
Initial Problem: When I turn on the 72, the red light on the dash (in the top part of the gauge on the left side of the dash) blinks and won't stop. I've made sure the e-brake is all the way off. I'm wondering where is the switch that controls this light? I've read that when the brake master cylinder is replaced, there is a switch on the MC that needs to be reset. I used a MC from Rock Auto and there is not reset switch button. Only the electrical switch that activates the brake lights. I have a brown wire that is connected to nothing in the area of the e-brake handle. I've tried grounding it but the light still blinks on the dash. Any advice would be appreciated. Click here for video of the blinking light: Blinking red light (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858110.1.jpg) Master cylinder: (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858537.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858538.2.jpg) |
Spoke |
Feb 11 2017, 10:32 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
The brake warning light will flash if the brown wire by the e-brake is grounded. Also if the switch on the MC is closed. Try disconnecting the wires on the MC switch and the e-brake wire is not grounded. This should cause the flashing light to stop.
vin man |
Feb 12 2017, 11:46 AM
The brake warning light will flash if the brown wire by the e-brake is grounded. Also if the switch on the MC is closed. Try disconnecting the wires on the MC switch and the e-brake wire is not grounded. This should cause the flashing light to stop. I took the wires off the MC and the wire off the switch at the handbrake. The light still flashes on the dash. |
rgalla9146 |
Feb 12 2017, 12:23 PM
Advanced Member Group: Members Posts: 4,545 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
The brake warning light will flash if the brown wire by the e-brake is grounded. Also if the switch on the MC is closed. Try disconnecting the wires on the MC switch and the e-brake wire is not grounded. This should cause the flashing light to stop. I took the wires off the MC and the wire off the switch at the handbrake. The light still flashes on the dash. Find the wire at the hand brake switch and disconnect it. Follow it out of the seat crossmember and wherever it goes to be sure it is not making contact with anything that could ground it. |
vin man |
Feb 12 2017, 01:31 PM
The brake warning light will flash if the brown wire by the e-brake is grounded. Also if the switch on the MC is closed. Try disconnecting the wires on the MC switch and the e-brake wire is not grounded. This should cause the flashing light to stop. I took the wires off the MC and the wire off the switch at the handbrake. The light still flashes on the dash. Find the wire at the hand brake switch and disconnect it. Follow it out of the seat crossmember and wherever it goes to be sure it is not making contact with anything that could ground it. OK, thanks. I've got family stuff do do today so no more working on the car till tomorrow night after work at the earliest. Will keep going on the electrical debugging at the shop asap! FYI - I did pull the relay that was causing the flashing. While the red light did go off and stop blinking, the turn signals also stopped working. Apparently, they share a relay. (IMG:style_emoticons/default/biggrin.gif) I put the relay back as turn signals are important. |
Lo-Fi Version | Time is now: 5th May 2024 - 09:44 AM |
