Troubleshooting my electrical issues., My first problem was blinking red light on the dash for brakes |
vin man |
Feb 11 2017, 06:08 PM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
Edit: Renamed the thread because what started out as one electrical problem has led to others and I'm hoping to capture all the information in this one thread.
Initial Problem: When I turn on the 72, the red light on the dash (in the top part of the gauge on the left side of the dash) blinks and won't stop. I've made sure the e-brake is all the way off. I'm wondering where is the switch that controls this light? I've read that when the brake master cylinder is replaced, there is a switch on the MC that needs to be reset. I used a MC from Rock Auto and there is not reset switch button. Only the electrical switch that activates the brake lights. I have a brown wire that is connected to nothing in the area of the e-brake handle. I've tried grounding it but the light still blinks on the dash. Any advice would be appreciated. Click here for video of the blinking light: Blinking red light (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858110.1.jpg) Master cylinder: (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858537.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858538.2.jpg) |
Spoke |
Feb 12 2017, 01:58 PM
Jerry Group: Members Posts: 6,978 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
You can pull the bulb out to stop the flashing.
vin man |
Feb 12 2017, 03:45 PM
Spoke |
Feb 12 2017, 05:03 PM
You can pull the bulb out to stop the flashing. The relay will stop flashing when the bulb is removed. See the turnsignal/brake warning schematic below. one of the wires from either the MC switch or the e-brake switch is shorting to chassis. Removing the bulb will break the circuit and the flasher relay will not operate. This isn't a fix of course because somewhere the wire to the MC switch or e-brake is grounded. When you fix the grounded wire, you can put the bulb back in. My guess is the brown wire to the e-brake is touching the chassis under the seat or throughout its run to the bulb. Attached image(s) |
Lo-Fi Version | Time is now: 5th May 2024 - 04:47 AM |
