Troubleshooting my electrical issues., My first problem was blinking red light on the dash for brakes |
vin man |
Feb 11 2017, 06:08 PM
Member Group: Members Posts: 178 Joined: 19-February 10 From: Gilbert, Arizona USA Member No.: 11,380 Region Association: Southwest Region |
Edit: Renamed the thread because what started out as one electrical problem has led to others and I'm hoping to capture all the information in this one thread.
Initial Problem: When I turn on the 72, the red light on the dash (in the top part of the gauge on the left side of the dash) blinks and won't stop. I've made sure the e-brake is all the way off. I'm wondering where is the switch that controls this light? I've read that when the brake master cylinder is replaced, there is a switch on the MC that needs to be reset. I used a MC from Rock Auto and there is not reset switch button. Only the electrical switch that activates the brake lights. I have a brown wire that is connected to nothing in the area of the e-brake handle. I've tried grounding it but the light still blinks on the dash. Any advice would be appreciated. Click here for video of the blinking light: Blinking red light (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858110.1.jpg) Master cylinder: (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858537.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/i304.photobucket.com-11380-1486858538.2.jpg) |
914_teener |
Feb 14 2017, 08:17 PM
914 Guru Group: Members Posts: 5,197 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Man...ya get bonus points.
Keep at it. Have you "rung" out every wire for continuity and then checked the ground points. Also...how bout the wiring? For years my windshield wipers didn.t work correctly. Turned out after I replaced the fresh air fan some DAPO had scabbed on a connector to the switch and shorted one of the hot leads behind the cowl. Hang in there check the wiring diagram and physicaly check every wire if you can get to it. |
Lo-Fi Version | Time is now: 5th May 2024 - 03:51 AM |
