914 measurements-how accurate do I need to be |
amfab |
Feb 12 2017, 09:52 PM
Member Group: Members Posts: 393 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None |
After some minor welding, I wanted to check the car’s level and dimensions again. I hung the doors, made a couple of jack stand adjustments, and everything looks pretty good.
I measured key dimensions and I am wondering how precise I need to be. I measured:
These measurements are essentially dead on. I think the inaccuracy is probably because of my measuring ability. I also measured between the hinge and door lock pillars (h). These are a little big. They are about 3/64 of an inch more than the factory dimensions, but they are the same on each side. With all the other dimensions being so accurate and the doors looking pretty good, I am wondering if I am being too worried about the precision of this. Or am I? Are these numbers pretty good for a car made in the 70s? Thanks, -Andrew |
timothy_nd28 |
Feb 16 2017, 11:01 PM
Advanced Member Group: Members Posts: 2,299 Joined: 25-September 07 From: IN Member No.: 8,154 Region Association: Upper MidWest |
Hey Andrew,
It seems that you are having great luck to where to place the measuring tape when making measurements. I'm trying to decipher the location points for "D". I have looked at the pictures and drawing a blank like a idiot. I bought a 914 shell and recently just started to fit panels to it. I think the front face panel has pushed in, as I only read 40". |
amfab |
Feb 17 2017, 10:13 AM
Hey Andrew, It seems that you are having great luck to where to place the measuring tape when making measurements. I'm trying to decipher the location points for "D". I have looked at the pictures and drawing a blank like a idiot. I bought a 914 shell and recently just started to fit panels to it. I think the front face panel has pushed in, as I only read 40". I'm not working up there so I haven't made something for that, but I find measuring anything with a tape to be a problem. What I do is use dowels that I cut to the dimension to measure between easy stuff like in the door jamb. for the harder dimensions I use dowels with screws perpendicular through the end that stick out a bit. To get "D" you will probably need to make a custom trammel gauge out of a metal ruler with a plumb bob on one end like cary said. |
Lo-Fi Version | Time is now: 26th May 2024 - 01:47 PM |
