STILL NO BRAKES! |
STILL NO BRAKES! |
JHop |
Feb 14 2017, 06:59 PM
Newbie Group: Members Posts: 28 Joined: 18-February 16 From: Portland, OR Member No.: 19,685 Region Association: Pacific Northwest |
Gents,
I have done the searches, watched some video, looked up stuff, rebuilt my calipers, replaced the MC, soft brake lines, and some hard lines, new pads and hardware, adjusted the venting clearance on the rear pads, speed bleeders...probably going on about $600 all in on this brake system so far...bled , then bled, then bled some more using a pressure bleeder...still a soft pedal and red blinky brake dash light when the pedal goes to the floor. I tried to do the pedal bleed, but it didn't seem like the fluid was moving. When I switched to the pressure bleeder, the fluid started coming out...no air bubbles. What am I missing? Adjust the venting again? If I did that wrong, does it screw up the whole system? Car runs, is looking good...needs to STOP. (IMG:style_emoticons/default/headbang.gif) |
porschetub |
Feb 14 2017, 07:21 PM
Advanced Member Group: Members Posts: 4,697 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have you bleed off the calipers in the correct order i.e.furtherest to nearest from the m/c /,what brand of m/c did you buy?,is your brake pedal adjusted for correct stroke?.
Have you replaced the brake fluid,old shity stuff can wear out new parts in no time...ask me how I know. Whole bunch of questions I know but I'am not in your garage to see whats going on. Good luck. |
JHop |
Feb 14 2017, 07:27 PM
Have you bleed off the calipers in the correct order i.e.furtherest to nearest from the m/c /,what brand of m/c did you buy?,is your brake pedal adjusted for correct stroke?. Have you replaced the brake fluid,old shity stuff can wear out new parts in no time...ask me how I know. Whole bunch of questions I know but I'am not in your garage to see whats going on. Good luck. Hey there! Yeah, I did the correct order...not sure about the brake pedal...all new fluid. have an ATE MC... Would it make sense to check the venting on the rears again? I'm so frustrated, I'm about to cave in and get it towed to my indy....I just want to fix it myself... |
Lo-Fi Version | Time is now: 28th April 2024 - 08:39 PM |
