STILL NO BRAKES! |
STILL NO BRAKES! |
JHop |
Feb 14 2017, 06:59 PM
Newbie Group: Members Posts: 28 Joined: 18-February 16 From: Portland, OR Member No.: 19,685 Region Association: Pacific Northwest |
Gents,
I have done the searches, watched some video, looked up stuff, rebuilt my calipers, replaced the MC, soft brake lines, and some hard lines, new pads and hardware, adjusted the venting clearance on the rear pads, speed bleeders...probably going on about $600 all in on this brake system so far...bled , then bled, then bled some more using a pressure bleeder...still a soft pedal and red blinky brake dash light when the pedal goes to the floor. I tried to do the pedal bleed, but it didn't seem like the fluid was moving. When I switched to the pressure bleeder, the fluid started coming out...no air bubbles. What am I missing? Adjust the venting again? If I did that wrong, does it screw up the whole system? Car runs, is looking good...needs to STOP. (IMG:style_emoticons/default/headbang.gif) |
wndsrfr |
Feb 14 2017, 08:46 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Gents, I have done the searches, watched some video, looked up stuff, rebuilt my calipers, replaced the MC, soft brake lines, and some hard lines, new pads and hardware, adjusted the venting clearance on the rear pads, speed bleeders...probably going on about $600 all in on this brake system so far...bled , then bled, then bled some more using a pressure bleeder...still a soft pedal and red blinky brake dash light when the pedal goes to the floor. I tried to do the pedal bleed, but it didn't seem like the fluid was moving. When I switched to the pressure bleeder, the fluid started coming out...no air bubbles. What am I missing? Adjust the venting again? If I did that wrong, does it screw up the whole system? Car runs, is looking good...needs to STOP. (IMG:style_emoticons/default/headbang.gif) Did you "bench bleed" the MC before installing....if not, do it. |
Lo-Fi Version | Time is now: 28th April 2024 - 03:57 PM |
