Engine died on freeway, Need help diagnosing (EDIT: solution found!) |
914 RZ-1 |
Feb 14 2017, 08:30 PM
Porsche Padawan Group: Members Posts: 683 Joined: 17-December 14 From: Santa Clarita, CA Member No.: 18,230 Region Association: Southern California |
So I'm cruising along in 5th gear at freeway speeds and the engine goes out. Didn't hear anything, no warning lights went on (that I saw). Got the car off the road. Nothing loose or dripping. Plenty of gas. Battery is strong. Car turns over but won't start. Anybody got any ideas where I should start checking?
I've got newer trigger points, a Pertonix ignition, fuel injectors work and I recently replaced 2. I have an after-market fuel pump that has worked fine. I was recently working under the dash but if I jarred something loose it seems the car wouldn't have started this morning. i checked the distributor cap and it looked OK. EDIT: It was the fuel pump. I've only had the previous one for 15 months. Called the company and they sent me a new one. Car is working fine now. Thanks to all who contributed. I appreciate it. (IMG:style_emoticons/default/beerchug.gif) |
StratPlayer |
Feb 14 2017, 08:38 PM
StratPlayer Group: Members Posts: 3,270 Joined: 27-December 02 From: SLC, Utah Member No.: 27 Region Association: Rocky Mountains |
It just quit,, sounds like something electrical.
snakemain |
Feb 14 2017, 08:39 PM
Ronin Member Group: Members Posts: 577 Joined: 14-January 10 From: Aviano, Italy Member No.: 11,232 Region Association: None |
First thing to check that happened to me after a complete restore on my first long trip...Ended up having a vacuum on the fuel tank due to no venting on the fuel tank due to carbs vs. FI. If you open the gas tank when it dies and you hear a sucking noise, that's your problem. You're FI, but still who knows.
wndsrfr |
Feb 14 2017, 08:44 PM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Fuel Filter or the screen in the tank clogged??
Elliot Cannon |
Feb 14 2017, 09:13 PM
Pertronix ignition??
timothy_nd28 |
Feb 14 2017, 09:15 PM
(IMG:style_emoticons/default/agree.gif) sounds like you lost spark
Feb 14 2017, 09:18 PM
914-6 GT in waiting Group: Members Posts: 19,255 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Mine did the same thing. Bad relay board in the engine compartment. Took me a while to figure out. (IMG:style_emoticons/default/headbang.gif)
GaroldShaffer |
Feb 14 2017, 09:27 PM
You bought another 914? Group: Benefactors Posts: 7,620 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
loose wire on the coil? My BIL 914 would die from time to time while driving. Happen to me while on a trouble shooting test drive with him. Took a while but found a spade on a coil wire was loose. It would slide on, but wasn't snug. Little pinch with some pliers and all was golden.
boxsterfan |
Feb 14 2017, 09:29 PM
914's are kewl Group: Members Posts: 1,776 Joined: 6-June 03 From: San Ramon, CA Member No.: 791 Region Association: Northern California |
Fuel pump died on my 1974 2.0L on the freeway. Exact same behavior.
914 RZ-1 |
Feb 14 2017, 09:43 PM
second wind |
Feb 14 2017, 10:01 PM
Senior Member Group: Members Posts: 851 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Completely clean battery terminals......my 2.0 did same thing....fixed in five minutes......we have had so much rain down here they are corroded to hell.....jus' sayin'
gg |
TheCabinetmaker |
Feb 14 2017, 10:46 PM
Elliott was not asking if you have pertronics. He read that in your post. He was suggesting that your pertronics has dumped! I agree! I had those for a while and it failed on the freeway, just like yours. Went back to points and I'm happy.
flmont |
Feb 14 2017, 10:58 PM
Senior Member Group: Members Posts: 879 Joined: 21-October 08 From: Tucson,Az Member No.: 9,676 Region Association: Southwest Region |
My fuel relay went bad,..
KELTY360 |
Feb 14 2017, 11:10 PM
914 Neferati Group: Members Posts: 5,031 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
iankarr |
Feb 15 2017, 05:56 AM
The wrencher formerly known as Cuddy_K Group: Members Posts: 2,472 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region |
I also vote for fuel relay issue or possibly overheated coil.
When this happened on my car, I found it would start fine and then unpredictability die after a while. Replacing the relay worked to get me back going, but it would die again sometimes days later without warning. Turned out the pin sockets in the relay board were loose, causing the relay to cycle whenever I went over a bump. The cycling strained the relay to the point of failure. I figured this out by starting the car and pressing on the relay. With slight pressure I could feel it click and trigger on and off. The solve was to make the pin sockets a bit tighter by slightly bending the metal. All good! The other time I had a similar dying issue it was related to an overheated coil. (I also have an electronic ignition module- Mallory). It was so hot that I couldn't put my hand on it for more than a second. When the coil cooled down, all was well. I added a ballast resistor and made sure the wires were solid and haven't had a problem since. The thing about pertronix is that when they fail, it generally happens like flipping a switch...unlike analog points which deteriorate over time. But once they're dead they're dead. If your car started up after the freeway issue, it's probably not your pertronix. Good luck! |
mlindner |
Feb 15 2017, 06:13 AM
Senior Member Group: Members Posts: 1,517 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I had it happen, ground wire to fuel pump.
GregAmy |
Feb 15 2017, 09:31 AM
Advanced Member Group: Members Posts: 2,285 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Fuel pump died on my 1974 2.0L on the freeway. Exact same behavior. Yup, that was my issue with my 74 2L. Same problem: died on the highway. Sometimes restarted with a key cycle and clutch release, sometimes not. So I tested and replaced the fuel pump relay and it worked. Or so I thought...replaced the TPS with new and that seemed to work for a while, then died again...then I was fighting a no-start and isolated it down to the relay board (or so I thought)...each time I get in there and move things around, the problem goes away for a while and then comes back so now I'm leaning toward wiring and/or connectors. Bottom line, the electrical system on these cars is approaching half a century and our relay board, relays, wiring, and pin connectors are in crappy shape. My goal for 2017 is to replace it all, start from a solid baseline, and work from there, even if I have to re-engineer the whole system with something more solid (it's not high-tech, just a lot of work). Not a concourse restoration so I'm not worried about that. Yup, bad relay. It's happened to me and I've also rescued 3 other 914s with the same problem. I always carry spares, but you can rob one from a headlight motor. Blower motor, right next to the fuel pump, or rear window heater if equipped. I keep a "known good spare" in the rear window heater slot (not installed in my car) |
Front yard mechanic |
Feb 15 2017, 09:38 AM
Senior Member Group: Members Posts: 1,158 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None |
Frist check spark secound check gas third check tow rope
ndfrigi |
Feb 15 2017, 11:19 AM
Elliott was not asking if you have pertronics. He read that in your post. He was suggesting that your pertronics has dumped! I agree! I had those for a while and it failed on the freeway, just like yours. Went back to points and I'm happy. my 75 1.8 FI also had same issue driving it from Mission Viejo cars and coffee and just died on a full stop a mile away from my house. Cranking strongly and after several test and diagnosed, ended up only the pertronix is the only issue! During my initial replacement of the pertronix and use points, it didnt fix the issue and had several items replaced or swap parts for 2 mos. And after all those, the new points I ordered from a reputable porsche parts supplier, is defective. Wow 2 mos and only issue is the defective points. just sharing my experienced. |
xperu |
Feb 15 2017, 11:46 AM
TEXAS Group: Members Posts: 597 Joined: 13-June 06 From: League City Texas Member No.: 6,213 Region Association: None |
So I'm cruising along in 5th gear at freeway speeds and the engine goes out. Didn't hear anything, no warning lights went on (that I saw). Got the car off the road. Nothing loose or dripping. Plenty of gas. Battery is strong. Car turns over but won't start. Anybody got any ideas where I should start checking? I've got newer trigger points, a Pertonix ignition, fuel injectors work and I recently replaced 2. I have an after-market fuel pump that has worked fine. I was recently working under the dash but if I jarred something loose it seems the car wouldn't have started this morning. i checked the distributor cap and it looked OK. Check all your grounding points, there are several and clean for corrosion. Ask me how I know. Mike |
Lo-Fi Version | Time is now: 6th May 2024 - 01:12 AM |
