AAV testing, Manual and electric |
malcolm2 |
Feb 20 2017, 05:59 PM
Advanced Member Group: Members Posts: 2,745 Joined: 31-May 11 From: Nashville Member No.: 13,139 Region Association: South East States |
Ok. I have had the AAV off for a couple weeks now. I figured it was time to re-install. Wanted to test it first.
I put it in the freezer. The valve was open before and after. I got the wife hair dryer out and got it hot enough to NOT hold on to. But the valve stayed open. I got my drill battery out and jumped it to the connector. Very quickly the valve closed. I decided to blow threw it. Air did not move quickly thru it, but i could hear the hissing as it came out. So the question is: is the AAV supposed to close up tight? |
Rob-O |
Feb 21 2017, 10:08 PM
Senior Member Group: Members Posts: 1,252 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Yes, my 85 VW cabriolet has one. So maybe the "hissing" is coming thru the electrical connection.... I can try to check that. 1995 would be newer than 1975 (IMG:style_emoticons/default/beerchug.gif) And it is only $55. But the electrical connector has a "tang" that is different. The tang isn't holding that connector on. Why not just dremel it off the new part? |
malcolm2 |
Feb 22 2017, 08:17 AM
The tang isn't holding that connector on. Why not just dremel it off the new part? The tang is for orientation. It would certainly work with out the tang. I suppose great care would be needed to keep the connections straight everytime you connect it. I don't want to be called a DAPO in 20 years when some newbie buys my car. (IMG:style_emoticons/default/WTF.gif) As much as i like the square aav, i like my harness more. I really don't want to hack it up. I have at least two maybe 3 other aav from other cars and spare engines lying around. I think i will pull them out and compare operation and how well they seal. |
Lo-Fi Version | Time is now: 15th May 2024 - 09:10 PM |
