Got 16" Fuchs in 6 and 7s, will they fit? |
RickS |
Feb 20 2017, 09:47 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
From my 82 SC I have a set of wheels and want to know if they would work on a teener with slightly flared rear fenders without using massive negative camber. The 914 is lowered and currently is on 15s, 6 and 7s.
Most importantly, what size tires? Would like to mount BFG Comp T/As Much grass |
DRPHIL914 |
Feb 23 2017, 07:06 AM
Dr. Phil Group: Members Posts: 5,766 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I'm going to say yes and no, not necessarily!- the 16x7" fuchs rubbed on mine and caused blistering of the paint on the fender!! - depends on the car-
I have 205/55-16 on front and rear- now, the fronts are 6^ and rears are 7" - but for our cars the proper diameter for the speedo is 205/50-16 since you already have 7" on rear of car with your 15" rims your 16" may fit , even after having fenders massaged to get the 7" to fit, its so tight, before I fix and repaint I will be going back to 6" rims, with spacer, - you see the 7" rims come out a whole inch further, the back space is same as the 6's, - if they were lets say a half inch less on outside and half more in, they would be perfect. but that is not the backset for the early staggerd 911 fuchs wheels. - but like I said, it varies from car to car, so good luck!!! Attached image(s) |
lonewolfe |
Feb 23 2017, 03:49 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I'm going to say yes and no, not necessarily!- the 16x7" fuchs rubbed on mine and caused blistering of the paint on the fender!! - depends on the car- I have 205/55-16 on front and rear- now, the fronts are 6^ and rears are 7" - but for our cars the proper diameter for the speedo is 205/50-16 since you already have 7" on rear of car with your 15" rims your 16" may fit , even after having fenders massaged to get the 7" to fit, its so tight, before I fix and repaint I will be going back to 6" rims, with spacer, - you see the 7" rims come out a whole inch further, the back space is same as the 6's, - if they were lets say a half inch less on outside and half more in, they would be perfect. but that is not the backset for the early staggerd 911 fuchs wheels. - but like I said, it varies from car to car, so good luck!!! I'm curious if you tried fitment of your front 6" wheels with those tires in the back of your car? If so, did that fit in the back without rubbing? |
Lo-Fi Version | Time is now: 19th May 2024 - 10:20 AM |
