Got 16" Fuchs in 6 and 7s, will they fit? |
RickS |
Feb 20 2017, 09:47 PM
Senior Member Group: Members Posts: 1,408 Joined: 17-April 06 From: 'False City', WA Member No.: 5,880 Region Association: None |
From my 82 SC I have a set of wheels and want to know if they would work on a teener with slightly flared rear fenders without using massive negative camber. The 914 is lowered and currently is on 15s, 6 and 7s.
Most importantly, what size tires? Would like to mount BFG Comp T/As Much grass |
RichPugh |
Feb 24 2017, 07:52 PM
Member Group: Members Posts: 129 Joined: 28-October 14 From: Baltimore, MD Member No.: 18,068 Region Association: MidAtlantic Region |
I'm running 16x7 23.3et all 4 corners w/ 205/45 Toyo R888R's. I grabbed the rear fenders by hand and brutely yet gently pulled them out a couple mm. Fits like a charm (IMG:style_emoticons/default/smile.gif)
lonewolfe |
Feb 24 2017, 08:56 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I'm running 16x7 23.3et all 4 corners w/ 205/45 Toyo R888R's. I grabbed the rear fenders by hand and brutely yet gently pulled them out a couple mm. Fits like a charm (IMG:style_emoticons/default/smile.gif) Humm, that's very low profile. Do you have a picture? I have a set of four 16x7 Fuchs. I bought 205/50/16 Yokohama S-Drive tires yet to be mounted. I figure some rear fender mods will be needed. I also have both a full set of 6x15 and 7x15 Cookie Cutters. |
RickS |
Feb 26 2017, 12:07 AM
I'm running 16x7 23.3et all 4 corners w/ 205/45 Toyo R888R's. I grabbed the rear fenders by hand and brutely yet gently pulled them out a couple mm. Fits like a charm (IMG:style_emoticons/default/smile.gif) Humm, that's very low profile. Do you have a picture? I have a set of four 16x7 Fuchs. I bought 205/50/16 Yokohama S-Drive tires yet to be mounted. I figure some rear fender mods will be needed. I also have both a full set of 6x15 and 7x15 Cookie Cutters. I am trying to get away from 15s to get away from the limited assortment of performance tires, especially S Drives. They grip well but but during hard cornering at speed, the sidewalls load up and when they release, they spring back like rubber bands totally unsettling the car. At 50+ going into a curve is a white knuckle experience. I love my Conti DWs on my 911 and abuse the hell out of them and they behave predictably. BFG Comp TAs also get extremely high marks. |
Lo-Fi Version | Time is now: 19th May 2024 - 08:36 AM |
