Just your basic oil and filter change, please., And no thanks, I'm past the days of doing it myself. |
914Next |
Feb 21 2017, 09:54 AM
Senior Member Group: Members Posts: 699 Joined: 28-July 14 From: Ephraim Wisconsin Member No.: 17,695 Region Association: Upper MidWest |
So I don't put that many miles on my '73 but do change the oil once per year. I'm beyond the days of doing it myself. Just not worth the hassle of the mess and disposing of the oil.
I do have a very trusted independent service garage where I take my car for all service work. But it takes a bit more effort to make an appointment and drive the car out there since it is 12 miles away. And I'm not sure they even really want to mess with a simple oil d and filter change. Would be much easier to just zip down to a trusted oil change place and do it there. Am I making a mistake taking it to an oil change place and risking that they mess something up? |
rhodyguy |
Feb 21 2017, 11:12 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,079 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
More than likely one of the 'fast lube' places would remove the screen cover to drain the oil then tighten it up real good. Breaking the internal boss and sending you home on a tow truck with a permanent leak. Then when you try to collect on the $7k+ motor THEIR employee broke, you will get laughed at.
914Next |
Feb 21 2017, 11:29 AM
More than likely one of the 'fast lube' places would remove the screen cover to drain the oil then tighten it up real good. Breaking the iternal boss and sending you home on a tow truck with a permanent leak. Then when you try to collect on the $7k+ motor THEIR employee broke, you will get laughed at. We'll, when you put it that way..... Thanks! |
Lo-Fi Version | Time is now: 14th May 2024 - 02:35 AM |
